Fob and key won't unlock doors or trunk!
Hi, I'm a new member and you can read about me in the new members area. This is a great site! I've owned my 98 XK8 convertible for almost two years. The other evening I parked it and locked it using the fob as I always do. The next morning I go out to the car and click the unlock button and nothing. I tried it again and again and still nothing. Trunk...nothing. I figure a bad battery so I replaced that the next day and came home and still the same results! OK so I start doing some research...I took the fob apart and cleaned all the contacts with a Q-tip and alcohol and put it all back together. Still nothing. I tried using my key to open the trunk...nada. I tried the key in the door and again nothing. I'm going to call a locksmith out here tomorrow if I can't find a solution. I suspect it's a fuse. HELP!
Thanks!
Thanks!
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
