Fog Light Issue 1999 XJ8
Guest
Posts: n/a
So I thought I had a simple fix when i noticed that the light was out. Bought an exact replacement, popped it on in there aaaaaaand...nothing. Left one is going strong but the right side has just given up. The wires leading into the socket look fine, but I am hardly an electrical engineer. Can anyone shed some light on this problem? Fuse? Wiring? or is it just a mystery that I will have to shell out $$$$ at the dealership to get resolved.
Your thoughts/comments/concerns are greatly appreciated
My guess would be the socket. My Hummer used to have problems with the sockets. Clean it well with WD40 and see if that helps. You could also put a tester on the socket to see if any voltage shows up. Likely, if the bulb does not light, then there won't be, but this will rule out a faulty NEW bulb.
JagtechOhio, I didn't mean to make it sound that way. I respect your oppinion GREATLY! I just happen to have the manual on my computer in PDF.
PS: Until I read this, I never knew the headlights were seperate. Good info for future.
thedugger1
09-24-2015 05:32 PM
