ford part#'s for primary chain guides for 4.0dohc single roller chain
I need to confirm that I ordered the correct parts. My car is a 98 vdp with 4.0. Does ford part# 2w92-6k297-ab(I ordered 2 of) for one or both guides? Am I correct that the right and left bank use the same part #'s. I just need to make sure, am I dealing with four(one for each guide),two(inner and outer guide)or one(2guides sold as one part) number(s)?
In other words, if I want to order all four primary guides from ford what part #'s do i order and how many?
Here is the Ford part numbers and quantities that have been circulating for a couple years. Prices may be a little out of date but still substantially below any Jaguar supplier for the same parts.
I just noticed that the quantities for the primary tensioners are wrong. The quantity should be one of each part number.
I will confirm when I get my parts but it seems that the quantity is correct. what is wrong are the descriptions, from what i can tell:
zw92-6k297-ab is guide without tensioner
zw92-6L253-aa is not tensioner as list says, but the guide that tensioner pushes on
If someone knows better let me know.I will update when I confirm.
yup i got the correct parts, the above is confirmed description is what is off---- 9-23-2010
danke
10-03-2015 09:31 PM
