Free play in driveline.
I recently acquired a 1999 VDP with 120,000 on the Odometer. I did not receive any service records. I have a local shop that specializes in Jaguars here in Oakland ca. Anyone familiar with there work? The car makes noise (a clunk) when shifted between drive and reverse and back, I also hear the noise by rocking the car back and forth when parked. Noise seems to be coming from around transmission. To me seems to be a loose/ sloppy ujoint, but I am completely new with Jaguars a have not gotten under it and looked. Any help on what it may be or what I should be looking for? Thanks in advance for your time.
Jim
Jim
Water pump can also fail, but was addressed early by Jaguar, if the pump has black impeller it's time to change it.
The only was for sure to check tensioners is pull the timing covers, it's a half hour job, so not difficult.
Hope this helps
Woznaldo
09-26-2015 11:02 AM
