Fried ECM 98 Jaguar Xj8l 4.0 is the dealer the only option if too fried to be repaire
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hey,
I bone headedly gave someone a jump and my feline friend hasnt started up since. Afyer two months in the shop, I was told the ECM is fried. Is there anyway around going to the dealer to program another ECM from another jaguar?
1998 XJ8L Jaguar
Vin: 813400
1998 XJ8L Jaguar
Vin: 813400
motorcarman (05-06-2015)
Another thought: contact ASI and explain what happened, ask if it is worth testing to see if rebuild is possible. That would be the cheapest fix if it can be done.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
motorcarman (05-04-2015)
A good used ECM will work if the numbers match AND you perform an 'immobilization setup'. Basically it tells the modules to 'shake-hands' with the 'new-guy' so the engine will start. I have had to install good-used ECMs to get sensors operating again when the ECM circuits 'fried' internally.
I had one recently that faulted BOTH VVTs and it was NOT a wiring or actuator fault. I installed a replacement ECM, performed the immo-setup and it did NOT fault the VVTs. I re-installed the old ECM, performed 'immo-setup' and the fault returned!!!! It was a faulty ECM.
WDS or IDS will perform the setup. I don't know if other diagnostic machines will work.
bob gauff
bob gauff
The following 2 users liked this post by motorcarman:
Samilcar (05-05-2015),
test point (05-05-2015)
bob gauff
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
smokin_hobo
08-29-2015 12:13 AM
FS[Western US]: Ecm 2005 xjr
dsetter
08-26-2015 12:14 AM
