front pad replacement
I'm a little late gettin here, but you should bleed off fluid at the calipers and NOT the reservoir. Reason being the fluid at the calipers are heat stressed and need to be replaced on a regular basis. The brake fluid sees extreme heat and pressures starting at the caliper, so you should drain this fluid off first. Also any dirt that gets into the system will settle out at the lowest point which is the calipers.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
