Front Shock Bushings
Old 06-23-2010, 07:13 AM
ixj8it's Avatar
Default Front Shock Bushings
My front lower, possibly upper too, shock bushings are worn. Is there a polyurethane replacement for these lower bushings? Is it advisable to use polyurethane in this position or should I stick with the stock style? I am not sure what all options are out there so maybe someone can chime in. Thanks!
-Rob
Old 06-23-2010, 08:25 AM
TN8Shooter's Avatar
Mine were shot too. I just purchased the kit from British Parts online and they are awesome. You will have to use a press to remove the old ones and to install the new ones. Really easy DIY job if you have the tools. Also, if your steering feels loose check the front control arm (think thats the correct name) under the car. Good luck.
Old 06-23-2010, 09:57 AM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
I haven't found any poly bushings manufacturers for our cars for anything but sway bars, end links, and control arms. If you need those, i can give you a link.
Old 06-23-2010, 04:35 PM
MidlifeXJR's Avatar
h20boy, I would like the link for the sway bar bushings. I have been looking but all I've found is the universal ones.
Old 06-23-2010, 04:45 PM
H20boy's Avatar
Sure, Powerflex USA, I ordered a set of sway bar bushings and end links for mine. Have not arrived yet, but looking forward to getting them on.
Old 06-24-2010, 11:06 AM
TN8Shooter's Avatar
Please let us know how the bushings work out for you. I would love to purchase a set for my XJR.
Old 06-24-2010, 10:18 PM
MidlifeXJR's Avatar
h20boy, do you know if the XJR is a 33mm bar, I assume it is, but I can't find it listed anywhere and Powerflex lists two sizes.
Old 06-25-2010, 11:04 AM
H20boy's Avatar
I'm pretty sure the Rs do have a larger sway bar, I've read that somewhere in the past. You could take a string (floss), measure the circumference, and calculate it.
Old 06-25-2010, 08:38 PM
MidlifeXJR's Avatar
... You could take a string (floss), measure the circumference, and calculate it.
That would be too easy... I never thought of that, I'll check the next time I crawl under!
Old 06-26-2010, 07:36 AM
ixj8it's Avatar
OK so back to the original topic. Where do people get these shock bushing kits for the XJ8 besides motorcarsltd/britishpartsonline? When I ordered the ABS tone ring socket the other day, it cam with an advertisement for polyurethane XK8 shock bushings.
So where else do you guys get your parts? Thanks
-Rob
Old 06-26-2010, 10:56 AM
H20boy's Avatar
I don't know about the XJ8, but the XKs (of similar years) no longer have bushings available separately to purchase. If the XJ shock is also similar (not adaptive) its just as economical to buy a shock $100 with the new bushing already pressed in. labor rates in jag documentation are identical as well.
Old 06-26-2010, 03:00 PM
MidlifeXJR's Avatar
-Rob
CoventryWest has the uppers as a kit for the XJ8, but I think they are more money. I don't see the lowers anywhere. http://store.coventrywest.com/cgi/co...Y=JAG147A26010
h20boy is probably right that buying a shock is now becoming the choice for worn bushings.
Old 06-26-2010, 05:52 PM
ixj8it's Avatar
I wish someone would measure the diameter of the XK8 bushings and compare them to XJ8 bushings. I know that motorcarsltd has poly uppers for the XK8 that look similar in pictures to the XJ8 lowers. My lowers are shot, but I wont be a buying a whole shock to fix it unless the shock itself is toast.
-Rob
Old 07-09-2010, 01:42 PM
H20boy's Avatar
The sway bar diameter on the XK8 is 25.6mm, I measured 4-5 times using my caliper, always just a few hundredths larger or smaller.
A follow-up on the powerflex bushings I linked before, they still hadn't gotten the rears in after 6 weeks, so I canceled my order and got some OEMs to solve my little problem.
If you plan on ordering from them, anticipate a longer wait time (~6 weeks) as they have to special order it from overseas (the UK IIRC).
Old 07-09-2010, 11:49 PM
MidlifeXJR's Avatar
... A follow-up on the powerflex bushings I linked before, they still hadn't gotten the rears in after 6 weeks, so I canceled my order and got some OEMs to solve my little problem.
Thanks for the update. I haven't ordered them yet, but I was planning on it. I may go the same route and order OEM's.
Old 07-10-2010, 09:18 AM
Received 2,192 Likes on 1,358 Posts
to my knowledge. NO lower front shock bushings are avail seperatly
Old 07-10-2010, 04:55 PM
H20boy's Avatar
midlife, if you can get a measurement for the bar diameter, you could try energysuspension.com, they aren't 'custom' fabricated for our cars like the powerflex, but if you're within a mm, they just might work.
Old 07-13-2010, 06:27 AM
ABoxley's Avatar
Have you guys tried britishparts,
http://www.britishparts.co.uk/.sc/ms...BSORBER%20BUSH
-lower front shock-absorber bush.
I've been looking at the kit for mine (about £135 for all front bushes for an XJR)
Just wondering if any of the tech's can give an idea of how much labour (in hrs or $/£ to change all the front bushes would be).
Oh, I think powerflex do a full front kit for XJ8/R's
http://cgi.ebay.co.uk/JAGUAR-XJ8-SPO...item439f87f2c0
-any one fitted/recommend poly bushes as I, and i imagine a few others, would be interested in checking them out.
Good luck with your search
Cheers guys
Alex
Old 07-13-2010, 07:45 AM
ixj8it's Avatar
You are the man! This place also has awesome prices on lower balljoints. I am getting new lower shock bushings and ball joints. The front lower shock bushing looks pretty easy to change. Hopefully I can at the absolute worst, just use a c-clamp to press them into the shocks. Although I should probably check out doing the top bushings at the same time. Thanks!
-Rob
Old 07-13-2010, 08:51 AM
H20boy's Avatar
From Jaguar documents:
-> labor to do lower bushings (on XK8) = 1.2 hours
-> labor to do entire shock (again on XK8) = 1.2 hours
All that is left is parts prices, that's why the shock is often just changed, more benefit for the same cost. Same goes for upper and lower control arms in essence.
Quick Reply: Front Shock Bushings
