Front Wheel Bearing Replacement
I am getting ready to change the front wheel bearings on my '98 XJ8 VDP, however I'm seeing some VIN ranges use the 76MM bearings while some use the 80MM ones. What's the actual VIN range (my VIN is 823166)? Advance auto parts has the 76MM ones in stock, part# 513058 but I didn't see anything for an 80MM one. Also the picture on Advance's website shows a sealed bearing which I'm guessing is pre-greased.
After reading on here about the ABS ring removal tool, some folks are saying there's a compatible Ford or Jeep tool that will remove it as well. If that's the case then I'd just take the whole assembly to one of those dealers to have them remove the ring for me (probably have them press out the bearings while they're at it too).
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
Bernie Posadas
09-03-2015 08:06 PM
