Front wheel bearings for 2001 VDP?
Guest
Posts: n/a
My 2001 VDP needs new front wheel bearings. I bought the bearings but based on what Jaguar says it would take about 500 dolllars worth of tools I currently don't have and believe me I have lots of tools. Anybody have any luck replacing bearings themselves?
Those wheel bearings can be tricky. Getting the spindle (vertical link) off isn't the problem. there is a nut that is also the wheel speed sensor ring. A special tool is made to take it off without damaging it. I have seen a few people take chisels to the rounded bits on the back side to try and spin the nut off. My suggestion is to take the loose spindles (vertical link) to a Jag dealer or specialist with the right tool to get the nut off and swap out the bearings. We did a number of them over the years. One guy kept bringing in his about three times to replace the bearings. He kept getting cheap bearings from China. I do highly recommend getting a quality bearing.
-Mark
-Mark
innzane
09-02-2015 10:08 AM
