fuel injector cleaner
I've just collected my car from the mot station and lucky for me no major problems although they saidwhendoing the emissions testthe there is alot of carbon from me doing short tripsand advised me to put some injector cleaner into a full tank of fuel.
what with them not being jaguar experts iwanted some advice really on what brand i should use & if i should be putting this into my xjr? i know STP make one.
thanks
lee.
Received 10,988 Likes
Using a good fuel and proper maintenance is a key to keeping the injectors clean. As for removing them cleaning and then reinstall I think that is excessive and not necessary unless you have a reason. As for cleaners, I have been using them from the time I started driving and that has been a long time. Today my primary choice of cleaner is BG 44k. I have been using it for several years with positive results, I should also mention that Jaguar along with other dealerships use it in my area. As for the Techron I have used it and if 44k was not available I would recommend it without hesitation. However you are the one that needs to be satisfied with the product. Either one you will not go wrong!
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
