fuel injectors
Hi
I am looking for a set of fuel injectors for a 1999 XJR, with better flow than I have at present.
book shows part number as LCC1521AD
also listed for the 4.0 litre naturally aspirated is LCC1521AF
They are physically interchangeable,
Without me purchasing one of each, would anyone know the fuel flow rates.
Received 13,107 Likes
Hi
I can't tell you about X308 injectors, but I researched XJ40 and X300 injectors and learned that the XJ6R injectors have a fuel flow rate of 380cc/min, compared to 220cc/min for N/A X300s. See my photo album below for more details:
Welcome to Jag-lovers - Members Photo Viewing Page
Do you plan to make other modifications to your system to accommodate the increased fuel flow rate of new injectors? Have you considered cleaning your existing injectors? Below are photos of the method I used at home, which yielded an increase in fuel economy of 2.67mpg on our '93:
Cheers,
Don
Thanks Don - Thanks Sami
Don, the vehicle is over 600HP
Twinscrew supercharger, 3 1/2" cold intake
twin 2 1/2" exhaust, Abaco MAF,
oversized intercooler radiator
Flowed and CC'd heads --- and more
Hi Don
reason I need bigger injectors is that I keep blowing up blocks at high RPM
it is leaning off I am running somewhere over 75PSI fuel pressure, I need to know that I can supply the fuel.
Thanks Sami, mine are the side entry type, yours should be too. I have been advised to make a fuel rail to suit top entry injectors, I am not that dedicated --- Maybe Andre is listening -- good project
Cheers and thanks guys
Hi Don
Don B (05-20-2014)
Here my injector results at 2.5bar.
Below are flow test results prior to cleaning the injector pintles. Tested at 2.5 Bar, 60 second flow rate. full open (static test).
1) 320 ml
2) 320
3) 317
4) 317
5) 320
6) 316
7) 316
8) 309
Average flow 316.88 ml
Low 309
High 320
Spread 11 (low to high)
Deviation 3.41 %
The deviation should be 3% or less. In your case, the deviation is 3.41 %. Due to injector # 8. All the others look good.
I only ultrasonically cleaned # 8, as the others looked good. After ultrasonic cleaning #8 is at 316 ml.
Now your specs are as follows....
Average flow 317.75 ml
Low 316
High 320
Spread 4
Deviation 1.79 %
They all now look good and ready to refit.
1) 320 ml
2) 320
3) 317
4) 317
5) 320
6) 316
7) 316
8) 309
Low 309
High 320
Deviation 3.41 %
Low 316
High 320
Spread 4
Deviation 1.79 %
Don B (05-20-2014)
Hi Don
Hi Don
600HP sounds like a jolly good time! Hope you can resolve the issues so you can enjoy all that power.
Cheers,
Don
Mine has a Kennebell S/C fitted, possibly more mods than Avos"s until recently,
I understand what you are saying, It's - or will be a 4.2 block, with 4.0 internals, Mine is built to a blueprint - flowed and CC'd heads,
I do have a BAP, still in box.
If you remember, you commented on my dyno about 6 months ago, about how lean it was mid range. (how much torque for little HP)- which was wheel spin on the dyno
This time round I am looking at a piggyback system, to take control of everything. xjr99 has good things to say about Vipec, their Parent company D-link is probably the one I will use,
Dc
Right, Steve M has the KB as well and ran 11.9, so 550+ HP on his 4.0
AVOS has more mods than just the KB TS, cams, etc + who knows what
Wheel spin on the dyno at approx 600 hp.....that should not happen. I've witnessed 900 hp dynos with no wheelspin.
Do post about the ECU improvements, that will be helpful for all those who go the way of the Twin Screw
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
XKE73EIconverter
09-26-2015 10:21 AM
