Fuel lines & rear axle
I have 2 questions: -
1) I am refitting a refurbed rear axle to my 1998 X308.. it's a 3.2 Sport. Before I put it in, I am also replacing the fuel lines as they look a little tired .
Someone else (my son.. bless him) removed the existing lines, so I don't know where the 'feed' from the filter at the back connects to the fuel rail at the front, or, where the 'return' connects from the fuel rail back to the tank, or, which is the EVAP line?
2 diagrams I have seem to conflict? Did the setup change before or after my year (Sep. 1998), or maybe the 4.0 is different to my 3.2?
It may seem obvious, but I want to get it right before refitting the rear axle. So a simple drawing would help if anyone can help, or just a note to say this goes there, and that goes on over there.. whatever?
2) Has anyone experience fitting PowerFlex Bushes to the 'A' Frame? I have the instructions etc. to fit the bush into the 'A' Frame itself, but on the original bushes there's a spacer ring that sits on top of the bush on each side. The PowerFlex instructions make no reference to this spacer, should one be fitted when changing to PowerFlex Bushes.. does anyone know, because PowerFlex UK don't!!
Many thanks in advance
Paul
Paul
Paul
Paul
Side note on poly bush kits for our cars, when I spoke to a senior engineer @ Jag about them he mentioned the XJR bushes have a higher shore hardness than poly, meaning it wasn't worth the work. If you're going from comfort then it probably is.
