fuel pump out
Guest
Posts: n/a
fuel pump out
After buying some gas, my XJ8 died at the next light 300yds. away. The nearest dealer is 90 miles away, so I decided to try and scope it out 1st. I found the fuel pump fuse in the luggage area, and it was OK. I also changed the breaker with another one in the same luggage fuse box, and the fuel pump still did not work after that, as the car would not start. I tested the fuel rail with the ignition on, and a drop came out, but no flow with it on. I tried it later the next day, and still no avail. I then sprayed ether into carb throat to get engine going, which it did run, with steady ether spray, but no gas produced by fuel pump to keep the engine running. What else can Ido, butfigure the fuel pump is toast? Don't know ifthere is some other reason the fuel pump lost power to make it function. HELP!
Bob
Bob
