Fuel pump question
Fuel pump question
Hey fellas, I have an '02 XJR with 85k miles and am going to be replacing my fuel pumps for the first time. I've been researched and read every post I could find here about replacing fuel pumps but have one question: would I HAVE to remove the subframe to disconnect the fuel lines? I have bigger arms, and will be using a lift to get under the car...not sure if that matters much. Any input would be appreciated.
Brian
Brian
Thanks for the info guys. I ended up disconnecting the rear end of the drive shaft and disconnecting the parking brake cable. By doing this, I was able to get in there and disconnect/reconnect the fuel lines. The only issue I ran into was not being able to get one of the pump brackets out of the tank. For some reason, the bolt on the primary just wouldn't come out. All in all, the info I found here made this project a lot easier!
Charlene n John
09-28-2015 06:01 AM
deanh
09-06-2015 08:20 PM
