Fuel pump replacement
I just wanted to share my experience when I changed my fuel pump. When I removed the tank I was being lazy and instead of going under the car and disconnecting the fuel lines I left them on and was able to pull the tank out enough to get to the fuel pump inside. I put the new pump in then put everything back together. I went to start the car and when I stepped on the gas the car would bog down like a clogged fuel filter. Changed that and the same thing. I was going nuts trying to figure out what was going on. I thought the new pump was bad. Was not that. Finally I figured it out. When I pulled the tank out I stretched the fuel line under the tank. The fuel line has some kind of plastic tube inside the rubber hose. The plastic stretched so much when I put the tank back it kinked the hose. And no fuel was getting through. So take the time to disconnect the bottom fuel lines eventhough u can pull the tank out enough to change the pump. Just something to keep in mind
The following 2 users liked this post by Cburden0127:
JimmyL (03-14-2014),
WaterDragon (03-14-2014)
It is the right thing to do but the lines are extremely hard to get to. I didn't think there would b much harm a fuel line should have some flexibility to it. But as I learned it's not just a normal fuel line. The feel line has a plastic tube inside. That has very little movement before it stretches and it does not go back. And that is the cause of the kink
