Fuel Pump Replacement
This is to all the so called "Mechanic" or whatever you want to call them out there. Some advise for you when you replace a fuel pump XJ's, XK's or just any car. DISCONNECT THE FUEL LINES FIRST, you know, SO YOU DON'T CRUSH AND BEND THE RETURN AND FEED LINES. Anyway thank you so called "Mechanic," more $$$$$$ in my pocket.
