fuel pump testing
fuel pump testing
1999 xjr, I think I have fuel pump problem, car starts for only a second, sometimes will run a little. I pulled the fuel line off the filter, gas comes out just for a second then stops. checked the relays and replaced them with others of same kind and still same problem. then I jumped across the pins and the car runs and idles good although I didn't take it on the road.
I then jumped across one at a time and it ran on one and not on the other. does that mean bad fuel pump or should I do more testing?
1/when ignition is turned on, pump #2 energize for a few seconds to built up pressure then stop
2/ when starting/running engine, pump #1 is turned on
3/ above a certain rpm's pump #2 is turned on to supply extra fuel
4/ if an electrical problem is detected with pump #1, pump #2 take over pump #1 duty
powellwm (12-29-2011)
Guy-Pierre Boucher
09-16-2015 05:55 PM
