Fuel pump wire
tigger,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
As I requested in my reply to your Intro in November 2013, please add vehicle details to your forum signature.
https://www.jaguarforums.com/forum/n...member-106148/
We're good but we're not psychic.![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Stephan1997 (01-24-2021)
I have often wondered this as I have replaced probably at least 50 or more just between the X308 and X100 cars. I believe it's from the pumps themselves slowly shorting (failing) internally and creating more amperage and overheating the wire?? I might be wrong, but I'm sure someone smarter than me will chime in.
Received 1,792 Likes
You obviously have a short causing a surge you need to trace. I'd be more than suspicious one of your body grounds isn't connected, thus shorting your fuel pump wiring. Another possibility would be a pinched and/or bared wire leading to tank or your fuel pump itself burned out and shorted.
The black sealed bit is a radio suppression circuit.
It is best described as a LC circuit which someone else
can explain. The patent drawing is available on the internet.
Denso patented a radio suppressor built into the pump itself,
so Walbro, the OEM for the Jaguar pumps could not use the same
arrangement. To be competitive they introduced the outboard
radio suppression circuit and patented that.
If the LC circuit is on the ground side and the ground stud is
always the one that goes brown, then I would suspect that
the LC circuit is causing it due to resonance. Or, something
as simple as the added weight of the dongle loosening the
spade connection creating higher resistance followed by
heating/charring.
I just tossed mine and had it replaced with fuel grade Teflon
insulated wiring.
heating/charring.
insulated wiring.
A clogging fuel filter could also cause the power required to pump fuel to increase and lead to higher than normal 'amp draw' on wires not rated for it.
Jaguar recommends fuel filter replacement every 30,000 Miles.
A worn pump AND a clogged fuel filter will likely draw some serious AMPS!!!!!
bob
bob
