Fuel sender location?
I think I've got a bum fuel sender. Gauge is stuck at ~1/8 tank.
Lot's of threads/photos regarding replacing the fuel sender. It is supposed to be - I think - on the back of the tank. You can see it clearly here (part #8):
http://www.jaguarclassicparts.com/il...es/sd6470a.jpg
My car, a 2001 XJ8 L, manufactured 12/00, does not have a fuel sender there. I have a flat surface there - looks like you "could" cut it, and mount a fuel sender if you were so inclined... but it is solid metal right now.
I assume my sender is part of the fuel pump carrier? I've got to slide the tank out to access it through the fuel pump hole? My biggest question is: what part am I likely to need?
I think this is the part that would go on the back of the tank; the part I don't have/need:
FUEL TANK PETROL LEVEL SENDER / SENSOR UNIT Jaguar XJ8 XJR 1997-2002 (X308)
Maybe this is what I'll need?
http://www.ebay.co.uk/itm/NEW-JAGUAR...-/161078167186
Thanks-
Ryan.
Thanks-
Ryan.
Okay, in your case, your fuel sender is accessed from the top of the gas tank. It is a pain in the rear to get the fuel sender out. You have to empty the tank of gas, remove the fuel lines from under the car and remove the fuel tank out from the trunk first. Then you can access thru the hatch on top of the gas tank. You will have access to the two fuel pumps (on XJR) and fuel sender. Since you have the tank open, you might as well replace the fuel pump(s) and filter(s) along with the sender. Be sure you get a replacement rubber access hole gasket before you put everything back together again. Look at Amazon.com for parts. I got my parts from Advanced Auto Parts at:
Advance Auto Parts: Car, Engine, Batteries, Brakes, Replacement, Performance & Accessories
Please see attached photos:
Don B (08-23-2015)
Sorry to hijack this thread but perhaps those of you looking at the fuel tank can help. I have a leak in the female part of the quick disconnect unions. Obviously, i'll have to remove the tank to get at the area. Here are my questions...are the unions repairable? Are those lines external to the tank? I haven't seen a clear enough picture to help me figure out what is possible...
Thanks, in advance, for any help...
Thanks, I did look at the photos. Another question I have regards those fuel lines, with the female quick disconnects, that appear to run inside the tank...do they? I guess I'm expecting the worst and assuming the unions can't be repaired and wondered if those lines can be removed to be replaced...
smgdata (12-10-2021)
deanh
09-06-2015 08:20 PM
