Fuel Tank
The Vehicle Care Handbook gives a total capacity of 81 litres and a refill capacity of 75 litres for both engine sizes:
The Parts Catalogue lists 5 different part numbers based on VIN but makes no mention of different capacities:
I wouldn't like to try fitting an alternative (non OE) tank to the X308!
jamwilbat (08-30-2013)
I was once forced to go 9 miles beyond empty in an X300 on a dark, wet night in Yorkshire, UK. Never chose to repeat the experience with the X308 that replaced it but I've no doubt they will be similarly calibrated.
After the warning light came on, the range gradually dropped to '1' as the miles rolled by and then stayed on '1' for a further 8 miles until we finally found an open Service Station.
Although the Handbook shows 6 litres remaining from the 'empty' warning, I'm convinced there is actually more than that left in the tank at this point. However. I don't plan to test this theory!
Do let us know how the experiment with the jerry can goes!
jamwilbat (08-31-2013)
jamwilbat (09-11-2013)
jamwilbat (09-12-2013)
OK finally run out of petrol. Litres used showed 69.2 and managed to get 80klm from light on. Nows the interesting bit, I put 4ltrs in to get me to the garage and it took 76.5ltrs to fill up! Something is not right somewhere and only getting 22mpg on a long run is pretty woeful for a 3.2ltr. Used to get 28 on my 5,4l V12 BMW at 140k's. I know I mix up the metric with imperial but I am steam driven!
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
