Fuel tank removal
Fuel tank removal
I have a 2000 XJ-8 Vanden Plas with a fuel flow problem the fuel pump wont run. Could it be the crank Positioning sensor? Is there an acess door for the fueltank to remove it from the trunk. So I can replace the fuel Pump. Also how do you remove the back seat Back portion?
Fuel tank removal
Thanks again and again Jag_genuis . Before I try and remove the fuel tank and get to the pump.
I disconnected the connector on top of the Blue cap on the fuel tank and had someone turn the key to on and check with a volt meter from the connector (4 places all four sockets one at a time and it appears that there is no current going to the fuel pump)to ground) I swapped out the fuel pump relay and checked fueses under the hood in the trunk and behind the kick panels under the rear seat.) There is current to the fuel pump relay any suggestions.
OP -are you saying there's 12 V across the pump relay coil, 12V input to the relay contacts
but 0v output with the relay connected?
In that case swap the relay for another of the same colour and see if that corrects things.
If not please post exactly what volts on each relay pin with it connected.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
