Full Load Breather Hose
OK I finally got the FLB hose routed through but I can't get it to clip onto the TB. Any tricks? I can get it on and almost snapped... Just can't seem to get that last little bit. So at this point I walked any so I wouldn't break anything else. I didn't take off a lot of suff. Disconnected several electrical connections. Can see it just can't get the push.... Please help???
You talking about the part-load breather hose? If so, I had the same dilemma. In the end, I just had to use a little more force than I felt should have been necessary. When I did however, it made a very satisfying "snap" sound and I moved on.
I am hesitant to tell you that though, because I don't want you to break something and feel that my advice was responsible. I'm just telling you my experience. I pushed it very hard, and it snapped onto the throttle body connection.
larney (06-01-2016)
Yes I did mean the PLB. Had to replace both due to not being careful.
Didn't know if there was a trick or something. Part of it I think is the awkward position of trying to push up. So just push a little harder? Don't worry I break crap at my own risk... Without anyone's help. Just push harder is the trick...
Thanks.
Thanks.
larney (06-01-2016)
larney (06-01-2016)
