Fuse Blown
Fuse Blown
My Cigar lighter fuse burnt out! In trunk fuse box, #5, the 25A fuse was out. Discovered when attempting to use compressor to inflate tire. Nothing else on that circuit. Easily replaced fuse & was able to use the compressor w/o problem. I’ve never had a car fuse blown b4 & wonder why it blew? I suspect somehow excess current went through that circuit. I don’t think fuses just blow due to a defect in the fuse itself after many years.
Iconoclast (02-03-2013)
Eureka!
Just remembered that a few days ago when picking up my car from service, the car wash guys had left a small washer & tiny bit of broken plastic on the console. I didn’t know if that came from my car or not so put them next to the cigar lighter & when I removed lighter I accidentally knocked that washer into the lighter socket! I fished it out with a finger but, I think it caused a short in the circuit by bridging the gap between two metal contacts in there.
I am no longer going to throw loose change or any stuff in that area even temporarily.
Test Point, if I had not remembered that washer falling in there earlier today, reading your reply just now would surely have reminded me! Mystery solved!
