Fuse question
Fuse question
I lost illumination on my overhead console when I was replacing a tiny bulb. lost light on the running lights that light the map on/off button, not the map or dome lights, instrument cluster, shifter console switches and driver side door/window pack and the radio/heater switch lights.
All my fuses check out as good, or my inexpensive fuse tester says so. I went for No 18 on the left hand heelboard and replaced the 5 A anyway.
What am I missing??? Instrument panel lights work when ignition is on but not when engine is running. No running interior lights for center console, radio/AC, etc.
abonano
25
09-25-2015 10:43 AM
