Gap in air intake system
Hi guys. Well I've had my Jag for about 3 years and just decided to do minor work on the car myself. As I was looking at the engine, I noticed a gap in the Air system between the hose and the air box. Am I missing something there? The hose is stiff and doesn't stretch to close the gap. Any info or suggestions appreciated and I Love the site!
![Name: 0408010831.jpg
Size: 55.6 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/172989d1501289190-gap-air-intake-system-0408010831.jpg)
cclipse01: Based on my experience, there's nothing missing. The intake going to the throttle body should have an accordion section just past the tube coming in from the valve cover. If you loosen up the clamp, you should really be able to tighten up this gap. You could remove intake from throttle body, tighten up the gap, and then place back onto the throttle body, being careful not to burger up the gasket. Good Luck, and I too love this site!
cclipse01 (04-10-2011)
clubairth1
29
05-10-2024 12:57 PM
