gas guestion
I have done tests on both my 99xk8 and my 95xj6 and I put the results on my page. Many will differ but with my wife’s and my driving I see no advantage to the higher octane other than having your engine run cleaner. By the way the 99xk8 is a daily driver. http://www.gusglikas.com/AutoRepairMPG.htm
Long, involved, subjective discussion!
Bottom line: To achieve the HP advertised by the manufacturer you need to use the octane recommended in the owners handbook.
Other opinion: The car is designed to manage engine knock (ping) through knock sensors and spark advance management by the ECM. Therefore, using 89 (US) octane will not cause pre detionation. The car will no longer be able to achieve the advertised HP but, personally, I would never be able to determine that.
Great l o n g discussion here:
https://www.jaguarforums.com/forum/s...ad.php?t=31594
