gas pedal limiter?
That is your kickdown switch. Makes the tranny grab a lower gear when you floor it.
You should check your throttle cable adjustment to make sure you are getting wide open throttle when you floor it.
Search for "throttle cable adjustment" in the 308 section and the info should come up.
Vector
Vector
jimforrest (uk)
02-28-2019 06:42 PM
