gas tank access question???
Tank has two straps holding it in, then almost looks like it would tilt down to change the fuel pump. Am I right? Or do you have to pivot the passenger side toward back of car because the filler neck won't allow it to "tilt"? ![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/48461-gas-tank-access-question-quote.gif?dateline=1374054854)
This is in a 2002 XJ8 where I have 10.5 volts DC on the two small gauge wires at the white connector at tank, so I assume pump is bad. Have no fuel pressure at valve on fuel rail.
Thanks for advice on getting to pump!
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
