gas tank ventilation problem?
hi everyone as allways I come up with strange problems
something is wrong with my gas tank after some driving if I open a gas tank cap the pressure goes out (its quite big pressure, the cap stays in the air for a while) newer happened before. in the JTIS I found out that there is some kind of solenoid under the bonnet that regulates the presure in the tank.... what the hell is that ? is it fixable? where should i look for a problem?
ok.... then perhaps the reason could be "gravitex" (I sprayed the botom of the car few weeks ago it's this stonechip thing) I remember those hoses one of them goes to some small black box not far from differential... guess I have to get under the car, if it's posible to somehow damage this walve by sprayng on it then probably it will be the reason..
Thanks for the advise..
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
