Gear box cable
The part number is MND4830BE. Unfortunately, it seems no longer available. If you cannot find a new ore good used one, see if there are workshops in your area that can make you one using the parts from the bad cable that you have.
For non - north American X308 supercharged models which is a Mercedes-Benz W5A580 or Mercedes-Benz 5G-Tronic different then a non - supercharged model
https://www.jaguarclassicparts.com/u...-control-cable
See other cars to maybe pull from
https://en.wikipedia.org/wiki/Merced...c_transmission
Maybe go to an aircraft hanger and see if they can repair the original cable assembly
All you probably need is the inter cable
FS[SouthWest]: s type PAC aux box and jaguar connector cable
qwiketz
12-06-2016 02:24 PM
jagqueen
03-20-2014 08:48 AM
qwiketz
07-06-2010 01:02 PM
