Gear lever stuck in P
Hi - my jaguar 2001 X308 worked ok last night -this morning the car starts but cannot shift the gear out of Park - the P is illuminated - the rear brake lights work. Has anyone else had the same issue and if so what is the cause? is it fuse? any help most welcome. Thanks...just tested the winscreen washer - wipers working but not the screen wash- not sure if its related. Also I did a hard reset. Battery is good current just under 13 v
Regarding the fuse just have a look at #10 Amp5 in the engine management fuse box it is responsible for :
Engine control module, Park/Neutral switch, cruise control VSV 1 and 2 (where fitted), EGR valves.
The engine management fuse box is the one under the bonnet which is nearer to the windscreen
The RHD has two fuse boxes. A smaller and a bigger one (more to the front of the car) both next to the suspension. The smaller one is the one I mean.
The following 2 users liked this post by motorcarman:
Bert Kamphuis (06-25-2020),
bforsik (06-24-2020)
What a piece of information. I am very curious about what the thread starter will say about it.
Link to diagram: http://jagrepair.com/images/AutoRepa.../jagxj2001.pdf
Thank you all for responding to my problem.
motorcarman (06-24-2020)
paigeinaldo
10-15-2013 08:54 AM
