Gear shift plate replacement?
Hi
There is two Ebay items that list - XJ 1998-2003 transmission shifter cover.
Here are the weblinks:
1998-2003 JAGUAR VANDEN PLAS TRANSMISSION SHIFTER COVER | eBay
1998-2001-02-2003 JAGUAR XJ8 TRANSMISSION SHIFTER COVER | eBay
You should call JagBits (888-524-2487), they might be able to get a used one for you. They have shift selector covers for some of the earlier models listed on their website.
SHIFT SELECTOR COVER (PRNDL). FITS XJS UP TO 1993 VIN 188105 WITHOUT SPEED CONTROL SWITCH (price is $25.93).
Hope this helps.
Jim Lombardi
Hope this helps.
Jim Lombardi
The Gear Selector Illumination Module for the Supercharged Sedan (W5A580) is different than the one for the Normally Aspirated (ZF5HP24) and they have different part numbers from some MYs (VINs). I don't know what years are compatible but you cannot just plug any Selector Module into any XJ and hope it will work. It is a NODE on the CAN bus (listen only) so it is important to get the correct one or you can shut down the network.
At least get a Selector Module from a SC car to have a chance at it working correctly.
bob gauff
bob gauff
Received 2,193 Likes
Jag-man (07-27-2011)
Check out this site:
2001 JAGUAR XJR SUPERCHARGED: HIT FRONT- MANY CLEAN PARTS AVAILABLE!!
Give them a call. They claim to have parts cars in stock. I'm pretty certain you'll find there what you need.
