Gearbox
Gearbox
Hi All,
I am trying to determine the revs that the gearbox changes up at.
This 2002 model XJ8 changes at about 3,000 rpm under normal acceleration. My last XJ8 used to change about 2,000 rpm. It was a much newer box with only 38,000 miles on it. The mileage indicated on the odometer on this car is 158,000. I feel a gearbox filter and oil change would be beneficial. Would this be likely to lower the revs? I am unable to find out if the oil has ever been changed at all. Thanks Bill W.
gearbox
Hi,
All I can say for certain is that the light in the sport button does light up when pressed and go out when pressed again. To me, when it is lit it indicates that the box is in sport mode. As yet I have only used it in "Normal" mode.
Could the light be going on and off as the button is pressed, without changing the "mode" of the box??
Bill W.
Bill W.
Hi,
Bill W.
Bill W.
(typical British...push in to make it normal...lol...like driving on the other side of the carriageway from the rest of the civilized world...)
What you seem to be describing is that your transmission is in sport, which would give you the elevated switch points (aprx 3K RPM).
Press the "S" button in, and your box should shift around 2K depending on how much loud pedal you give it.
shifting gears
Calmed down after a couple cycles.
Same thing happened when I took apart the interior to do some radio/bluetooth install. Battery disconnected for most of the afternoon. Same thing. Slightly elevated shift points for a couple cycles.
Has to learn your style...I try and drive, most of the time, so that the shift points are almost undetectable.
