gearbox fault 2000 xj8
just recent had "gearbox fault "up on screen....when you turn on jag first all is ok ..reverse is perfect but put her into drive and normally a few yards then" bang into limp/safe mode or else will only rev and then "bang"...safe mode(well you dont really get a bang ..just a lurch!! checked fluids all ok
can anyone help please phil
There's two possibilities;
A drum failure, it fractures and all you can get is reverse and 5th gear.
Or, bearing failure that allows the A drum to move, breaking an o ring, same result.
There may be other causes, but those are the 2 most common. Do a search on here, you'll find plenty of posts on the topic.
Mine is here - https://www.jaguarforums.com/forum/x...-bmw-x5-66718/
