gearbox oil check
Hi Roldano,
For example here:
https://www.ebay.co.uk/itm/For-Merce...YAAOSwpkFY5MsR
The link above is for the Mercedes trans, like in the XJR.
I see you have a 2001 X308 (i assume normally aspirated), so probably you have the 5HP 24 Automatic Transmission System.
For the 5HP (ZF) trans maybe this modification: http://www.meurosport.com/5HP24_Dip_Stick.php
For example here:
Roldano,
The dipstick is for the MB transmission (indeed only for checking the level), which you don't have i think;
for your ZF box this stick won't work, the second link is a workaround for the ZF.
See also the tread of Jim: https://www.jaguarforums.com/forum/x...-cd-faq-54942/
Roldano (04-12-2018)
Khb1
03-06-2018 03:05 AM
orangeblossom
02-28-2016 04:35 PM
qwiketz
106
10-22-2013 11:39 AM
