Gearbox question, driving style
My VDP is in the "S" mode all the time. Average MPG is 19,4 (city+freeway). I burn 91 here in CA, and I am not concerned about fuel consumption. A mile or two (even 10!) per gallon more, will not make ANY difference in my life.
What's up with changing avatars all the time Sandy?
tested the gearbox today and it appears that it really shifts fast enough on down pressing as when one uses S mode. But i will now drive on S mode too if it is recommended. I thought it was something which you can use if need to, but too hard on gearbox for daily use.
On mercedes it even switches it self of with the keys, wont keep your last selection.
is it because you dont want underreved 6th gear shift? Is it going to 5th gear so often? I cannot say, most of my driving is in the city but it shifts so smooth that i have hard times to count gears.
If your speed is below, say, 90-100kph, it's better to use fourth. Less shifts=less wear. And, for me, fourth gear gives the better fuel economy in that speeds.
sandy85 (11-28-2012)
P.S. Mine is almost perfect too, just need to be polished (so the british racing green can shine in all his glory) and a hood should be repainted, but i'm waiting for the spring
#28
Fourth gear can easily take you in excess of 180 km/h, so except for more relaxed cruising it is not really detrimental. Sometimes I hit the highway and don't remember to shift up for quite some time. The usual routine is to keep it in fourth until accelerated to cruise and comfortably situated in the flow of traffic, then shift to drive.
Holding it in fourth means the torque converter never locks. In drive at part load, it will try to lock around 90 km/h.
In town, the shifts from second to third are smoother than when in drive. This is with Sport mode on so this may have something to do with the transmission adaptive routines for this particular car.
Also in town, the combination of Sport+Fourth actually yields better fuel consumption numbers. This is probably due to the fact that starting in first gear gets the engine up to peak torque faster.
In short, you get a more responsive car and better fuel consumption in city driving.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![Icon Twisted](https://www.jaguarforums.com/forum/images/smilies/icon_twisted.gif)
#30
Sport+Fourth is easier as the shift lever only has to go down and over. Third is down, over and up. Me==Lazy
Of course that doesn't explain missing a good five speed manual ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Try Sport+Third on your next tankful if you can do it all in town. Clear your trip computer now, take a average fuel consumption reading at 100 km. Do the same when you change to Sport+Third. Do both without hitting the highway. This is truly an experiment where the acronym "YMMV" applies.
BTW, less changes is not necessarily less wear.
#31
my mirrors are somehow not firm, they rotate (housing, not the glass inside) by them self. I will have to try to fix them because don't want to send it to shop again only for that, but for it needs to stop raining at least.
ok thanks for the answer, makes lot of sense. Never knew it would not use first gear when in normal mode.
when i was looking for my cat (long year) i wanted it to be automatic. i drive a lot in city and traffic and it is too much effort to drive a stick. I also do not need to wear special driving shoes with auto gearbox. I never had own car with auto gearbox before except about 3 months driving a B-Class as company car. I always had a stick before.
#32
Apparently, if they have been pushed in by hand, they will flop around until reset by power.
#33
#34
I have just replaced my mirrors - they are not power folding, but had become a bit loose about the hinge and moved quite easily with the wind at speed. I got some second hand ones and swapped them, it's really quite simple.
However if you want to fix them I think there is a friction device inside the mirror that allows the mirror to move inwards under hand pressure, not sure if you can replace this...I will have a look a bit later. It was just easier to change mine (the motors had broken).
That said (as previous post) if they are power folding you have to re-cycle them to get them to set out correctly.
#35
#36
#39
My cat came with a loose driver's mirror. I put off the fix until I was ready to replace the inner door panel. It had a thorn pocket (few of them), so I bought all four door panels (complete with all hardware and speakers) on the junkyard (plus all the seats, climate control with heated seats, and center console).
To fix the mirror: remove the door panel (explained elsewhere on the forum), there is a black "triangle" that covers the mirror from inside, it's glued in place with some black silicon based glue (pliable), you need to slowly pull on the triangle starting on the bottom, and it will come off, with all the glue still attached (and can be reused). Once the triangle is off, you will see one torx bolt, tighten that, press the triangle back in it's place, and reinstall the door panel. VERY simple.
The only thing you have to be careful about, is pulling the triangle off,....if you start on the upper corner, you WILL crack it, because of the way it's shaped. If you do end up cracking it, ......you can have another one off of the junkyard for pennies.
#40
