Gearbox question, driving style
#61
woooooow
i love this forum, i am here like a month and it helped me so amazingly even though i am not an diY expert. I dont know how i will be ever able to thank enough for this help
so there have been some development with my mirrors, so not only i found that i have indeed power folding mirrors
but the suggested idea that i cycle it back and forth few times made them indeed firm again. At first they made only some motor noises, then one folded, then second unfolded and the first moved a little, then they both started folding and unfolding and now they sit tight in their place and dont wobble!
yea dumb moment for sure. RTFM
Thank you all!
Thank you all!
The giveaway clue was the wobble. And it isn't actually in the owners' manual. You could look until you were blind and not find it.
It is in JTIS at the remove/install of the exterior mirror glass.
If as a result of accidental impact, a powered fold-back mirror is moved 'out of position', it must only be re-positioned by initiating the fold-back sequence as described in this section. No attempt must be made to manually return the mirror to the normal position. Failure to adopt this procedure will result in vibration of the unlocked mirror head and consequent loss or distortion of rear vision.
Door mirror fold-back where fitted, to facilitate parking in confined spaces, can be initiated when the ignition switch is in position I or II, the mirror selector switch is in the central position and vehicle speed is below 19 km/h (12 mph).
Mirror fold-back is then initiated by moving the toggle switch rearwards and releasing it. The door mirrors are returned to the normal driving position by again moving toggle switch rearwards. There is no speed constraint on this operation.
In the event of a fold-back mirror becoming 'out of position' due to accidental impact, it must only be re-positioned by initiating the fold-back sequence.Loss of power supplies will result in loss of mirror fold-back memory. In the event of such a memory loss with mirrors in the normal position, fold-back will operate on second movement of the toggle switch. On loss of memory with mirrors in the fold-back position, they will return to the normal position on next fold-back operation.
What cycling technique did you use?
I really want power fold mirrors for street parking ... so fingers crossed. Tried it before, but you never know, could get lucky on the third try ...
ummm... anybody reading this at work will just have to wonder until after work ... soz
bonnequixote (06-28-2024)
#62
X308 drives wonderful during winter. I hate studded tyres, so i'm using regular winter tyres, no problems at all. Can park in snow, can drive on ice, car handles AWESOME. The only things i miss, comparing to the X351 (which i often used to drive while i was working in Jaguar Land Rover Russia) is heated windshield and heated steering wheel
And yes, the 40s/300s/308s are kinda rare, especially the "R" ones. Lots of S-types, X-types, X350, X250, X351. Few X100/X150
Yesterday and to day we have a snow storm over here. The snow is falling, following by an ice rain, forecast says up to 50cm of snow during weekend. But Jag still starts, runs and brings joy No need in landrovers
#63
So not only do you have stable mirrors now, you have power fold mirrors. All for the cost of pushing the switch a few times.
snip
snip
So if anybody as dumb as me reading it, you can fold it by pressing the mirror multidirectional selector up and down when the mirror switch is in central position (off). I just multiple times (about 10) let them flap like dog's ears and they somehow self tightened. Now they are very firm (before, it was as flimsy that it moved while driving) and i can hide them in parking garage without women's parking places
this forum is really immersive source of knowledge and how fast is everything handled is awesome. Even my shop didnt knew! They tried to fix the mirrors and said i should buy new one. Same with the antennae disabling etc. Sad i cannot help much to others as it helps me, but it should warm you that you make somebody happy and maybe if all goes well i will make some JF thank you wallpaper with my Kitty for fun.
The following 2 users liked this post by sandy85:
plums (11-30-2012),
richard thomas (11-30-2012)
#65
that is rumor what BMW and Daimler drivers spread. But is all about driving style. My first car was old 520, i put 165/80 winter tires on it and drove like a boss through mountains with still wet ink on my driving license. I had to be pulled out of trench few times but i would contribute it to showing off in front of my friends then car.
#66
Jags are fantastic in ice and snow. Most Winters I see Mercs and BMWs slithering around or sitting helpless with one wheel spinning, while the General tracks away like a main battle tank!
#67
#68
#71
#72
#73
#74
Both above posts spot on!
Fuse is 10A in R/H rear footwell....mine had a 15A in which had blown.
I replaced it with 10A and so far so good....I can only assume that something has happened previously that made the previous owner fit a 15A to see if it would be big enough?
I am guessing that the mirrors I replaced were either very stiff to operate around the pivot which would blow the fuse as the motors overload, or that the defective mirror glass (it had 'bled' within the electrochromatic layer) was shorting the system and blowing the fuse.
However, at the moment the motors work great, and I shall report back tomorrow that the mirrors demist properly!!
Note - No teabreak today, having a day off....Monday too!
#75
Yes, unfortunately sometimes people do that sort of thing in a misguided attempt to "fix" electrical faults.
sandy85 (11-30-2012)
#76
Quick note as a check for power mirror installation...
If you can manage to prise off the small triangular panel on the inside of the door to gain access to the attachment screw and electrical plug....have a look at the electrical loom on the mirror side of the plug....there are 12 wires if I remember correctly....if you can find a grey wire and a red wire (not red and green as that is in there too and you can mistake it for solid red) that should be in the outer 2 pins on one side of the plug or the other (12 pin plug)...then you should have power mirrors - the red and grey feed the power fold motor.
#77
You guys got me going for a while over here! I am blond, but not THAT blond,.....so I checked the #4 fuse (all good), put the selector in the middle, and fiddled with the round button,....nothing. No sound, no movement, nothing. So my VDP does not have folding mirrors (has every other option that was available!)! Not that I would ever use them, but I like when EVERYTHING works on the vehicle as it should, so I needed to investigate this.
My driver's side mirror was loose when I bought it, and I thought Sandy's problem is the same. The only thing that was wrong with mine was the loose torx bolt that holds it. Still puzzled how (and why) did it ever get loose.
And about snow driving,.......I LOVE it! Especially on the frozen lake, as I did MANY times. In general,....I hate snow, and I lived long enough in the Midwest (and SEVERAL locations in Europe), that I can live for the rest of my life without it (and I do since 1995). Over here in the California mountains (3-6K elevation), we get some, but it goes away quickly. My ranch is on 3200' and we had two days of snow last winter. Just to feel in the groove, I drive the Hummer on those days.
I owned a 911 in Germany, and drove it in the snow all the time. Stick, RWD, and you can have some FUN!
#78
A blown fuse could be something as simple as trying to operate the folding mechanism when there is ice on the pivot. Notice that the option is offered in concert with the heated mirror package. So, if freezing rain is expected, it is best to leave the mirrors unfolded because coming back to a car with frozen mirrors and no way to unfold would be not good. Mind you, it is very tempting to fold them to keep the mirrors clean ... but a bad idea.
So far .. no joy .. but have not checked the fuse yet.
#79
#80
I have a feeling that the pivot mechanism may become stiff over time which would lead to the fuse blowing as the motors struggle to move - I think that is what happened with mine....
...I will investigate a method of lubricating the pivot tomorrow, I am just off to the pub to lubricate my throat now....
