Glass Headlamp Replacement Part
Rock cracked the outer passenger side glass headlamp on my 1998 Vanden Plas. Can I just replace the one lamp with this single headlamp assembly:
https://www.ebay.com/itm/Jaguar-XJ8-...-1#UserReviews
or does it have to be the whole two-lamp assembly?
The salvage yards will usually only sell you the pair
but they only run 75 bucks a pair on E bay
The inner and outer lamps are different and the X300 and X308 lamps are different
spray some penetrating oil on the plastic palls that hold the individual lamp to the plastic mounting bracket , they break
try fist before ordering this single lamp without bracket
Had to replace both of my x300 assemblies. They did not hold up. Although same halogen bulb -- the X308's throw better beam. Interesting that Samilcar says individual available for the x308. When I bought my second R the low beam was cracked -- when I went to pick it up I could tell the difference Left and Right assemblies ... Jaguar replaced the other side.
fast feline
07-30-2023 10:51 PM
04SCat
03-06-2018 01:30 PM
Spyhunter2k
08-14-2016 11:07 PM
john_cook12
11-10-2014 02:06 PM
