Glove Box Lock
Okay....I have never tried to lock or unlock a glove box in my life on any car. Now I want to be able to lock the glove box on my jaguars. So I take the ignition key, and try to insert in in the lock on each car, and it is like the key is the wrong key. I am obviously doing something wrong, both with the key, and admiting to this problem on this post. Any help would be appreciated.
Well I don't want to tell you to break it, but I know mine is very hard to lock.. You could try lubricating the lock with graphite (proper lube to use on locks) and if you do break it loose it should be easier the next time. There is also the possibility that either the glove box was replaced or the rest of the locks were replaced at some point in time and your using the wrong key OR it's just plain old broken and you'll have to disassemble or replace it.
Hi John
Just went and tried mine and it works ok. Turn clockwise about 1/2 a turn to lock, and 1/2 turn anticlockwise to unlock. ONLY black key works, the green key doesn't which is the correct behaviour according to the manual. I believe the green key also won't unlock the trunk manually either (and the trunk release is disabled once you put the car into Valet mode). When the gloevbox is locked and you pull on the handle it feels VERY flimsy, so I'm not at all surprised that JtO has seen cars with the handles broken.
Agree with the suggestions to squirt stuff into it..... it's probably never been used since new (This was the first time I'd ever tried mine tonight!)
Anyway, you're better storing your gun under your seat so you can get at it easier :-)
The coolest way I've seen so far to have a gun handy in your car is my friends range rover. He has a hidden door in the wood trim on his dash and at the push of a button a 1911 slides out via a linear actuator. It's very james bond.. I don't know who did it for him, but it sure would be useful if someone tried to carjack you.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
