GoPro of XJ8 with some suspension and chassis at Sonoma Raceway / Shelby Club
The following 5 users liked this post by Maxim Karp:
BobRoy (08-05-2018),
Carnival Kid (08-07-2018),
deancantrell (08-05-2018),
Highhorse (08-05-2018),
Jhartz (08-06-2018)
Maxim Karp (08-05-2018)
All the pieces together worked great. Only issue was over heating power steering fluid. The handling was almost perfect. Very neutral and easily throttle steered. More steering mid corner in longer turns induces oversteer without lifting throttle. Brakes were my biggest concern but were wurpringly good. Here are the things done to get this set up working and hardened:
1. Replaced all engine gaskets and seals.
2. Replaced plastic thermostat and all possible plastic cooling components with metal.
3. Replaced all subframe and steering rack bushings.
4. Mina springs.
5. Rear springs packed to raise rear for ideal rake and better turn in.
5. Bilstein HD plus sports ( green ).
6. XJR rear subframe and differential ( to mount sway bar - stupid expensive ).
7. Powerhouse rear swaybar.
8. EBC Yellow brake pads.
9. Motul RBF 660 fluid.
The car is a beast and alot of fun.
4. Mina springs.
Im planning on developing this car now since it held up so well. Next up are sub frame braces, strut tower brace, 400mm monblock brakes, wide square tire / wheel setup with custom offset ( ~275-305 ), power steering cooler and custom reservoir, and maybe muffler delete but only if it passes sound levels at Laguna Seca.
192cobra
Motorsports
01-16-2018 01:57 PM
192cobra
Motorsports
02-13-2016 10:37 AM
