Got it running!
Old 03-29-2024, 08:58 AM
mayhem's Avatar
Originally Posted by Addicted2boost
The red gauges were a bright red led bulb change out. I replaced all my cluster bulbs to bright white led’s and I have a blue look to mine.
That affects the characters on the display too though?
Old 03-30-2024, 08:02 PM
Addicted2boost's Avatar
Received 1,061 Likes on 819 Posts
These were all bright white led’s including the odometer. I suppose if you were to use a bright red in your odometer that it would be overpowering enough to make the digits red also.
eliotb (04-02-2024)
Old 04-01-2024, 09:12 AM
lothar863's Avatar
Maybe?
My 01 xjsport was green. i will have to pull the cluster to look at it. I think there is a bulb out since the top of the speedo is a bit dim
Old 04-02-2024, 03:00 PM
lothar863's Avatar
M8 x 1.25
Thanks!
Looks like this part number from McMaster-Carr will bee a possible replacement.
91290A118
abit longer at 220mm
The window switch lights on the driver door are green. I am guessing someone has done somthing to change them to red.
Coil installed. Misfire is gone. Next up is checking the someones on mostly off tail lights and then into the driver side airbag
Andrew_BR
02-16-2022 08:26 AM
Cliffo
10-23-2015 02:59 PM
bm_auto3
04-10-2015 02:18 PM
mat32essex
11-30-2013 08:01 AM
XJ8JR
12-16-2011 12:14 AM
Quick Reply: Got it running!
