Has anyone seen this headlight accessory?
Here's a couple of sorta-similar products?
https://www.andysautosport.com/produ...h__H3302W.html
https://www.ebay.com/itm/12453844800...iABEgIA5_D_BwE
Addicted2boost (03-23-2021)
I found them here. Part number is JLM20435 and Jagbits supposedly has them in stock. They're called, headlamp protective cover set
https://www.jagbits.com/product/JLM20435.html
As to repairing them, you may want to look to the folks that do fiberglass or high temp plastics in your area? They may be able to coat them or do a filler like you would for windshield repair as the chemicals are similar.
Carnival Kid (03-22-2021)
Thanks CK. I looked all over the ones I have for a makers mark or numbers of some sorts to no avail. I knew about tinted/blacked out headlight covers for other vehicles but I didn’t even know about clears, much less for our cars being available. The top link gives an idea of what they might look like but the bottom link is just a lens only cover vs a whole component cover.
Thanks Extheatrekid. I never even knew Jaguar had these made.
Found this in Dresden,Germany:
https://www.ebay-kleinanzeigen.de/s-...1723-223-23489
One side damaged, but only 15 Euro's.
Resurrecting this older thread on purpose. As I mentioned above a few years ago, I have a set of these and have tried to figure out how to install them a few times over the years, but I can't figure it out. The OEM part number is JLM20435 as mentioned above. I broke a lens a while back, and they're getting really expensive! Fortunately I had a spare, but if I can protect them, that's what I'd like to do.
Does anyone know how to install them? If anyone has a set installed, and if you have time, could you snap some pictures? I'm a visual learner, so pictures help the most! I'm not even sure I can tell which is the left or right one!
JoohnPiierce
07-28-2020 12:11 PM
offroadking208
11-28-2012 06:06 AM
