Has my suspension dropped a little on the front
I was wondering if you guys could take a look at a couple of pics for me or provide any measurements for X308 XJR ride heights.
Im sure the time and weight is starting to take a toll what you guys think? Maybe the back has dropped a little to? How does your cat sit compaired with mine? Car is empty but with full tank of petrol.
Excuse the poor photos, just trying to give you an idea....
Cats Suspension
Ebay 501 sidelight bulbs simular to this
2 x ERROR FREE CANBUS W5W T10 501 5 SMD LED SIDE LIGHT BULB | eBay
The ride height of the car is measured from the centre of the wheel to the apex of the wheel arch, through the wheel centre line. For the European XJR models, the ride heights are as follows, assuming a full tank of fuel:
Front: 366mm
Rear: 358mm
From your photos is does look as if the front is sitting slightly low-unless it's a trick of the light & photographic angle...
Front: 366mm
Rear: 358mm
This is the document you need-the ride height specs can be found on page 69:
Vehicle Specification (1998-2003 all models).pdf
The XJR sits pretty much level, so your front & rear ride heights-whatever they measure out at-should be roughly the same...
Thanks guys just had a quick measure:
Front it showing 348mm at the front from the middle of the center cap, hope this is correct? (644mm from the floor) and 358mm on the rear (floor not measured)
So it appears im about 18mm out on the front (when measured from middle of center cap). But spot on on the rear. OR 10mm out if you say it should be the same as the rear....
What will cause the front to drop and what needs replacing?
The rear is dead-on if it is 358mm. The front seems to have dropped 18mm as you say.
The indicaton is that the front springs have sagged, or were replaced with lower ones at some point.
Unless it bothers you, or tracking cannot be set properly, there is no absolute need to do anything. Lots of people look for ways to drop the ride height and pay for the privilege. You have it already
And with a nice front down rake too.
It has a minor effect on handling in that the CG on the front is now lower so the rear is a little bit tail happy.
99xk8guy
06-05-2023 06:28 AM
Mugatu
22
06-23-2020 01:50 PM
02jagstype
09-04-2015 08:20 PM
