having starting issues
You do not have your care information on your post so I went to your profile to see that you have a 1998 XJR and I hope this is correct. I understand that you had it running one time and it shut down or did you turn it off? You say you cannot keep the car running or is it that you are unable to restart the car? Did you charge the battery to get it started? Do you know if you have fuel pressure and spark?
If it's been sitting for a while, the fuel filter and the gasoline are suspect. I guess we're assuming that there is no check engine light and no stored codes. Can your mechanic hook an OBDII reader to it ? That might help out if the fuel is good and there is good fuel pressure at the fuel rail.
