Headbolt stuck in and head of bolt is stripping a bit
Headbolt stuck in motor 4.0 v8 Jaguar
So guys here's a new question. Got all the bolts out for the drivers side head bolts but one of them. The one is the drivers side top front 13mm bolt. Not sure if the head stripped out or what. Got a new socket and it still wont work. It gets to that really hard place then the socket just spins and the bolt just wont budge.
Even after all this I still really like this car but the motor is giving me a headache as now that bolt wont come out. Can I heat it up with a torch or will that make it worse. Need help again and sorry guys for bugging you all about my Jag 4.0 motor
So the bolt is moving up to a point, then not budging ? If your socket is spinning on the bolt head it may have been damaged during attempted removal. Are you using hex sockets ?
You can try a bolt extractor socket which have got me out of trouble a couple of times, although it will toast the bolt head. Being only 10mm bolts the bolt head may snap off completely, whereupon you can remove the head with the bolt shank still in place and work on removing it then.
good luck !
AndyP
good luck !
AndyP
timsalyer (11-29-2013)
Check pricing on Land Rover, Lincoln and Jaguar headbolts and go with the cheapest out of the three, same bolts different bags. DO NOT reuse them, torque to yield. Some manufacturers allow one reuse and stake the bolt head so the next guy knows to discard them, personally I replace them as a rule regardless of situation or manufacturer recommendation
Yes I will replace the headbolts./ Think I will use the Lincoln LS bolts though as they are much less and I can not afford the jaguar bolts. I used a headbolt extractor and was so glad a friend loaned me his set. got them out and heads are at the head shop now being checked and repaired if needed. Thanks all for your help.
Question though will the torque of the lincoln LS bolts the same as the Jaguar? just wondering. I can get a set off ebay for like 33.00 as the jaguar bolts are like 30.00 each.
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-11-2015 10:04 PM
