Headlight Adjusment Switch?
omgimali (06-27-2017)
Obviously you need the switch
Then the wiring for it stop at the driver side A pillar electrical connector
You need to use pins on the outside of the connector to extend the wiring to the headlamps
You then need to get the electrical headlamp adjusters and modify the headlamps base/surround to make them fit and also make a all the electrical connections
Not that hard if you know what you are doing
