Heated seats and front and rear heated windows not working
hi all agin.i been having help with a heater pump.now at the moment i cant start the car as i have a plastic water pipe broke. now i went to press the front and rear heated windows on and nothing lights up on the switches.and this is the same for the heated seats.now will they only work if the car is running.if not then what can be the cause as they worked fine a week ago .any help would be most great full.oh this is on my xj8 2001 oh also were is the interior heater sensor is it the one mounted in the middle of the dash by the inside bottom of window screen.
Smudge67 (12-15-2017)
Received 1,796 Likes
Your ignition needs to be engaged in order for your climate controls and its accessories to function. You can turn on your lights, roll down/up your windows, but that's about it on ACC. If you turn your key a bit farther forward where all your dash indicators come on and your not starting the engine, climate controls and accessories should function (fan, vent controls, heated seats). Just don't do it too long, you'll eat your battery.
Agree with Highhorse on the need for full battery charge and key in Acc . It's a designers choice in electrical reserve usage priorities , starter being # 1
The interior climate control temp senor is on the lower left side of the steering column for LWD . Might be the same for RWB . Look for a tiny grill . Do not spray with a cleaner as there is a tiny electric fan that may get it's bearings degreased . You have to remove the panel to get behind there with a dry brush . Clean the thermistor bulb with solvent on a towel . There is also a external temp sensor . If you had heated front windows as in expensive gold filmed inner glass option than you would have 2 relays by themselves behind the small panel on the left front seat by the left foot .
Any questions , just ask
On my 2002 XJ8 LHD that interior temperature sensor is just to the of the trunk release button. On either side of that trunk release button there little grills. Behind the right grill is the temperature sensor.
To remove the grill you must remove the single Phillips head screw that is in the top of the the little binnacle that is just below the trunk release button. That trunk release switch can now be pushed from behind now (towards the rear of the car). With that switch removed, the "tube" for the temperature sensor can be seen on the right.
Care must be employed to remove the hard plastic tube from the temperate sensor housing/grill. This is done by pushing the hard plastic tube away from you (towards the front of the car) while rocking it a bit. Once the hard plastic tube releases from the grill, the grill can be pushed from behind into the cabin of the car. There are NO clips for the grill, just plastic fins that allow tension to hold it to the dash fascia.
With the grill out you can now remove the plastic connecting tube from the flexible rubber tube that holds the thermistor bulb. Clean that bulb as directed above by Lady P.
the-jag-guy
110
06-02-2015 10:50 AM
