Heated Seats, something new I found out
Received 1,794 Likes
Heated seats are the best, I suffer from back problems so generally won't buy a car unless it has seat heaters. One thing you can do to your X308 seat heaters is this simple little mod, which will have the potential to ignite those farts!! :icon_flamethrow
https://www.jaguarforums.com/forum/x...-solved-44965/
It's also not advisible to "let rip" if the air is on recirculate either!!
![Icon Nut](https://www.jaguarforums.com/forum/images/smilies/icon_nut.gif)
Originally Posted by Stu 1986;One thing you can do to your X308 seat heaters is this simple little mod, which will have the potential to ignite those farts!! :icon_flamethrow
[url
[url
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/seat-heat-solved-44965/[/url]
5pcs KSD301 Thermostat Normally Closed NC Temperature Thermal Control Switch
Five for $4 shipped! That is enough to do all the seats and if they are bit hot or cold, I can re-order a different temp cut off spec.
Vector
XJRay (12-26-2016)
