Heater in 2000 XJR does not blow cold...?
The title of this post should say heater does not blow "hot"
Bought this "new" 2000 xjr 54K miles.
Did a few engine mods, just got it back together running like a swiss watch.
Thought it would be a good time to run through everything to see what fix it list I needed to make...
The A/C blow cold, but the heater does not blow hot....fan works fine... what is the next step to fix this??
If it happens again, check that the Aux Heater Pump is working. It's a common failure on these cars. Without it, the water barely flows through the heater coil, if at all.
