Heater problem on xj8
Hi guys just joined so not to sure what I'm doing.any way I have a jag xj8 2001.when I'm driving the heaters are nice and hot when I slow down or stop they go cold.temperature is normal.pump was done 4yrs ago.could this be a internal heater matrix partial blockage. If so this would me a reverse flow flus. Now has any one know what else the problem could be plz .
1. Blocked matrix; will get some heat at idle, but getting colder if driving,
2. Aux. pump; will get colder at idle, but getting heat if driving,
3. Interior sensor; generally only getting heat with button at MAX.
I should suspect the pump again, especially as a blocked matrix should not give you much heat while driving.
First check; just lay your hand on it with key in pos II, it should vibrate.
This pump fail if the brushes are worn, do a google and you will see what happens.
You can repair the pump with new brushes, or buy a new pump (where a Bosch pump is wayyyy cheaper than the original Jaguar one).
https://www.jaguarforums.com/forum/x...3/#post1795189
Are you sure you don't hear the throttle body, the aux pump doesn't make noise (or should not at least).
PS. On a LHD car, the aux pump is on the left side, tucked between the wheel well and the engine, reachable from the top if you open the bonnet.
Not sure on a RHD, maybe same, maybe on the other side.
Hi guys I have taken the second pump off car today and tested it and it's dead.so I have stripped it down and the brushes have gone but I can't get the motor end through the body.any suggestions. Plus were can I get the brushes from.I can post photo but can't fin how to do it .if any one can tell me I can post thanks u
The link below is for the brushes sourced from the US . Ensure you order 2 . They're a little long and can be filed to fit . European and rest of world source ? Can you elaborate on " I can't get the motor end through the body " ? If you pull the impeller housing off the common rubber O - ring is probably swelled and can't get it back in and a new one can be sourced from the hardware store . I have an extra one somewhere to get you the size if I can find it .
.15" x .15" x .35" BRUSH 33A
To post a photo go to the go advanced icon and then the manage attachments icon then pull from choose file icon hit the open icon then the upload icon , give it some time to upload . The last thing is the save changes icon .
dude1579 (12-08-2017)
Good you found the source.
This one will tell you more than you will ever need:
Heater pump repair.
If not, there are plenty of other threads on the subject, easy peasy with google or the in-forum search function.
Heater pump repair.
Lady Penelope (12-03-2017)
